Motherboard + Processor
Hey guys,
Any oppinions appreciated. I’m building a pc and have decided to go down the AMD route. Now I have narrowed it down to a choice between two motherboard and CPU combos.
1.
Asrock motherboard A790GXH/128M AMD AM2 AM3 DDR2 ATX
AMD CPU AM2+ 9650 X4 Phenom 64 Quad Core Retail Box inc FanSocket AM2+
Total - £154.36
2
Asrock motherboard M3A790GXH/128M AMD AM3 DDR3 ATX
AMD ATHLON II X4 620 2.6GHZ SKT AM3 L2 2MB 95W PIB
Total - £160.82
I can post links if you like.
Basically I want to know which set up would be best as the price difference is small enough not to matter. I’m on a pretty tight budget.
Again any help appreciated:)
Herb
Here are some links for each set up to give you an idea of specs etc
AMD CPU AM2+ 9650 X4 Phenom 64 Quad Core Retail Box inc FanSocket AM2+ (3yr Manufacturers Warranty)- microdirect.co.uk
Asrock motherboard A790GXH/128M AMD AM2 AM3 DDR2 ATX- microdirect.co.uk
2
AMD ATHLON II X4 620 2.6GHZ SKT AM3 L2 2MB 95W PIB- microdirect.co.uk
Asrock motherboard M3A790GXH/128M AMD AM3 DDR3 ATX- microdirect.co.uk
Any input welcome because I really am struggling to decide either way,… maybe I should just flip a coin :slight_smile:
