hello, I have a question about my motherboard.. this is the type:
Gigabyte = GA - 819915MDG
what do you think about it?
thanks..
thanks..
I couldn’t find a board with that name. Could it be GA-8I915G-MFD?
And “What do you think about it” is a very open ended question.
What in particular do you want us to tell you about it?
what do you think about that motherboard ? is it good ?
if it works well ? or something like that..
link:
It’s good in the extent that it uses an Intel chipset, which are highly regarded for performance and stability. Secondly, Gigabyte makes pretty solid motherboards.
Is it an enthusiast-class motherboard? No, but typically, that’s not where Gigabyte caters.
thanks ..
