Mouse/keyboard cable
Hey all,
I am having a problem with my mouse, I am not sure if it is the cable that is the problem as I have only had it a short time.
Can anyone recommend anywhere I can get a decent mouse/keyboard cable?
Many thanks:) :slight_smile:
[QUOTE=goldeneye]
:confused: :confused: :confused: mouse / keyboard cables are attached to the device (keyboard / mouse)[ot]unless their wireless[/ot]
Well what’s wrong with the mouse? You are being a little vague.
If you want to purchase a new mouse, eBuyer is a good place to shop
you would be best buying a new mouse, rather than looking for a cable source for the broken mouse.
Thanks for the replies I found a good range of cables at Welcome to LINDY Computer Connection Technology so I am just going to change the cable and hope that is the problem:)
I still don’t get how you can change the cable to a mouse… it doesn’t just plug into the mouse, you’d have to take the whole thing completely apart.
