Mousepad problem
Hey guys, I’ve been looking at these two mousepads
http://www.Icemat.com/Ice.asp
http://www.Steelpad.com/Steel.asp
But I can’t decide which one I should get.. Have any of you tried them, and do you know if the msi 3.0 mouse is worth anything? Please answer me fast, because I can’t wait to get it :slight_smile:
Thx
Haven’t used either one of them. I’ve been satisfied with the Microsoft Optical mice I’ve been using and have no problems recommending them to anyone. I just haven’t needed to buy a mouse too recently, so I don’t know how the 3.0 works.
Yep for the price of the one I glanced at then (30 euros) Id just get one of Microsofts cordless optical ones. No mat, and no cord, its much better.
http://www.overclockers.co.uk/acatalog/Online_Catalogue_Desktop_Combinations_54.html
Ive got the one named…
Microsoft Wireless Optical Desktop - OEM (KB-010-MS)
For £39 you cant go wrong!
Okay guys, not alot of help on the subject, but thx. :wink:
lol, I think they suggested that there is no need for a mousepad, if you buy what they said :slight_smile:
I know, and I did say thanks. But I need a pad that has no friction at all, and my table is made of some weird material, so it sux…
I’m just using a cheap cloth pad from Best Buy. I’ve heard Ratpadz are good, as Everglide, but I’ve never tried them.
Hehe okay. :slight_smile: - Got a link mate? :slight_smile:
lol,
Ive got a melamine table here, with a big white patch where my mouse goes :slight_smile:
Good point, maybe mousepads arn’t dead after all !
www.ratpadz.com
www.everglide.com
I have to use a mouse pad since the top of my desk is plexi. I could take it off, but the steel desk underneath it has the paint chipped alot and makes a poor mousing surface.
Repaint it? :stuck_out_tongue:
And thx for the links! :slight_smile:
Naaah. Plexi is easier than sanding it down and repainting it.
