SYMPTOMS
When you use the Microsoft Windows XP device drivers for the Creative SoundBlaster Live! audio adapter, a memory leak can occur. This can cause the computer to lose system resources and run more slowly.
CAUSE
This problem occurs with the SoundBlaster Live! device driver that is included with Windows XP.
RESOLUTION
A supported fix is now available from Microsoft, but it is only intended to correct the problem described in this article and should be applied only to systems experiencing this specific problem. This fix may receive additional testing at a later time, to further ensure product quality. Therefore, if you are not severely affected by this problem, Microsoft recommends that you wait for the next Windows XP service pack that contains this fix.
