hi all need some help got my daughter this web cam set it up we can see but not hear they can see and hear us the cam is a logitech any help would be helpfull thanks steve: :mad:
What gadget you are using to speak and hear the voice? Does your computer play other files like music file?
Which connection do you have? Sometimes slow Dialup connection also affects the voice.
hi im usingcam with built in mike usb connection and im on broadband and my pc plays all sounds ok thanks steve
You ned to go through the msn wizard and make sure that it is picking your webcam as the source of the sound input.
