MSN Messenger not connecting
i couldent think of anywere else to put this so i though here would be ok.
last night, i could connect to msn messenger perfectly using my router, but this morning, it wont connect to msn messenger at all, i then decided to try my old adsl modem i got when i first subscribed to broadband, and msn messenger logged on perfectly, who could have happend that has stopped msn messenger from connecting??
Hm..MSN could be having problems, but I’m on it now fine.
Try the router again, it may have been a glitch.
i have tryed the router again, i have even tried firmware upgrade, i can get onto e messenger ok, wich is my msn account, i have installed and uninstalled msn lots of times.
also since i had router when i have bieng able ot get onto msn messenger, on the msn today screen, when i click on hotmail tab, its cant be loaded, also i have to load my email on aol most of time becouse internet explorer wont load, i tried trouble shooting it, bt it said it could not connect.
dry disabling any anti-spam prgorams of or pop up blocking, sometimes those programs interfere with chats or messangers
i have, i have disabled everything, i have tried port forwarding, port triggering, restoring router to defaults and setting it up agian, but it still wont work, i dont understand, when i uninstall msn messenger and reinstall it, all settings are same, its all ready knows my email and all i have to do is click sign in, is there some way to get rid of msn messenger so it start by scratch so there is nothing left of it, so i can set it up as if i have restored my computer, i dont understand why i have this problem becouse last night it was working perfectly, nothing was changed, so i dont know if its msn bieng idiots, but i can sign on using web messengers, and everyone i know and people who live near me can sign on, aol say that havent done anyhting, but msn works perfect withy modem, i cant use web messenger, its rubbish, if i cant solve this then i am going to have to say bye bye to msn, could my router have decided to break???
your internet may be disabling it considering it unsafe, check out also if you hadn’t blocked the connection via your firewall
the only firewall i have is built into router, and it cant be disabled, as i said, it was working ok with firewall last night, i dont have any other firewalls, something has ot be done, i have nieng trying for neary 6 and a half hours to get msn to work, but i have had no luck.
it seems like my computer must be broke, or router getting ready to explode, i dont get it.
I dont know if this may help but try doing ipconfig thing
you have to go to run first and type cmd and type the thing below
do this ipconfig/release then ipconfig/renew
i do it all the time i have trouble with something connecting it generally helps me
you can also try gettign a registry cleaner and erasing old messenger registry things and try a fresh instalation sometimes when you do restore system the programs are still on the machine
i dont understand that thing in command promt, is there anything that could show connection errors in msn???
