I just bought a jeantech achilles case.
How do i removed the covers of the trays where the disk drives stick out.?
thanks.
Shouldn’t there just be 4 plastic prong/clip like things that are molded onto the drive plate (2 on each side)? You just gently push each side together and the plate should pop out. Hope this makes sense and is relevant.
[QUOTE=Exfoliate]
Yea it worked, thanks.
Cool, glad I could point you in the right direction:)
