-Anti-Static Wrist Strap
-CD/DVD-ROM INSTALLATION KIT W/ IDE CABLE/AUDIO CABLE/MOUNTING SCREW
ANTEC PLUSVIEW1000AMG 21IN CASE 4X5.25 6X3.5 NO P/S W/ WINDOW SIDE PANEL
AMD ATHLON 64 3500+ S939 PROCESSOR NEWCASTLE 2.2GHZ 512KB CACHE RETAIL BOX
NEC ND-3500A DVD±RW 16X4X16 DUAL LAYER+R 4X INT IDE OEM W/ SW BLACK
COOLERMASTER TLF-R82-EG 80MM LED CASE FAN 4 LED GREEN 2500RPM 32CFM 25DBA (3 of these)
1.44MB BLACK 3.5IN FLOPPY DRIVE
SEAGATE 7200.7 120GB HARD DRIVE 7200RPM SATA W/NCQ 8MB 8.5MS 3.5IN OEM (for storage)
WD RAPTOR 36GB HARD DRIVE SATA 10000RPM 5.2MS 8MB 10K 5YR MFR WARRANTY OEM (for windows installation)
MICROSOFT DIGITAL MEDIA KEYBOARD & OPTICAL MOUSE COMBO BLACK OEM WITH SYSTEM ONLY
VIEWSONIC G90FB 19IN 18VIS .25MM 1600X1200 TCO95 BLACK
ASUS A8N-SLI DELUXE MOTHERBOARD NFORCE4-SLI S939 DDR 2XPCI-E16 2PCI-E 3PCI SATA RAID LAN SOUND 1394
MICROSOFT WINDOWS XP PROFESSIONAL OEM (WITH SYSTEM ONLY)
OCZ POWERSTREAM 520 WATT LOW NOISE POWER SUPPLY
OCZ DUAL CHANNEL OPTIMIZED PLATINUM 2X512MB DDR PC3200 HEAT SPREADER REV.2 CL 2-2-2-5
LOGITECH X-230 2.1 SPEAKER SYSTEM BLACK 32RMS 64W FDD2
-evga 6800gt pcie (when it comes out)
I am 99% sure that all of this is compatible together. Any suggestions on what else i should be getting? Anything else that i need to assemble this computer?
