Hello
I’m new at this forum.
I decided to move from tech-forums.net because they were unable to help me with this problem that I can’t fix ![]()
Here is a copy of my original post:
Before I tell you the problem I’m gonna say that I have read and read tons of forums and surf the web a LOT in search of an answer. So if some can help me with it would really be my [SIZE=“5”]savior[/SIZE] ![]()
This is the problem. My computer is like in SLOW MOTION ._. It’s really really slow.
The odd thing is that it happend over night.
Ok… This may take some time to explain but I think I better do it the right way and start from the begining, since I noticed the problem and also tell you the things I did in order to fix it, but saddly didn’t work. ![]()
I had just bought:
An Intel Core 2 Duo E4300 Processor.
An Intel Mother Board DG35EC.
4 Kingston dimm of 1GB of Ram.
A 512Mb nVidia 8500 video card.
A 17" LCD Monitor.
A new case with a 400W Power Supply and also a great cooling fan system and the PC is completly clean and free of dust or humidity.
Also I have this components from my old Pc:
160 GB HD IDE, I don’t remember the brand.
And a DVD-RW drive, also IDE.
(both on the same cord, since the motherboard only has 1 IDE port, HD master)
I had the Pc for over 2 months now… When bought the new components and built the new Pc I migrate the HD from the old one to the new one.
It used to have 3 partitions:
One was for Windows XP Home Edition SP2, 25 Gb.
The second partition was for My Documents (in case I had to reformat C:), 40 Gb.
And the third one was for Downloads and media files storage, 85 Gb or so.
Something that I souldn’t have done but I did was to “Repair” the Windows partition instead of reformatting and reinstalling the operating system, since this sometimes can cause problems. I also installed all the Drivers that came with my MB and Graphics card.
Eigther way the Pc worked beautifully !!! I was so trilled :love_at_first: (good times
) Windows started really really fast, all the StartUp software opened in seconds, I could surf the web with no problems at all, sound and graphics were great.
I could even play Dark Messiah and Half Life II, my favorite games on really high video settings, something that I couldn’t do with my old Pc.
Life was good ![]()
But 2 weeks ago wile I was using my Pc it started to run really really slow… This wasn’t after a restart of the Pc or anything, I had been using the Pc for some 3-4 hours now. So I restart the Pc and it took a LOT to run Windows, like 10 times more than normal.
When Windows was starting I got afraid because the music from the loging on sounded as slow as the Pc, each note sounded really long, as in slow motion and also like in cuts.
It took a lot too to start the StartUp programs and the problem continued all over the system, when I maximize and minimize windows, also when I start programs and everything !!!
All sound is choppy and slow, Media Player sound and Operative System sounds and also Msn and games sounds.
The slow sound is not consistant but it comes and goes when I trigger events like double clicking and etc…
Also if I have more than one program open… the performance of the Pc goes down.
The odd part is that when I check the Task Manager the CPU usage is under 10 or 15% and the RAM is way clear. But yet the Pc is lagging like crazy.
So I decided to reformat the partition in order to fix the problem and didn’t work.
Guys, pls !!! I don’t know what else to do.
Here’s a list of the things that I have done:
Reformat the partition 3 times in NTFS format and Install Windows XP Home Edition SP2, problem still not gone, lagging from the first startup.
After that I tried to defragment each partition in order to speed up the access time to the HD, still no inprovement.
Used RedCure to fix registry errors and some Hard Drive Testing software, that only showed me that my accessing time was near the lowest time registred.
Reformat ALL the Hard Drive in NTFS using a Low Level Format Tool and doing diferent size partitions and this time I installed the Windows XP Professional Edition SP2, because I read that the “Repair” I did on the WinXP earlier may have caused some inconsistency on the HD.
This did make the lagging frequency stop a little but didn’t fix it… also is still WAY more slower than my old Pc and takes the same long time to boot up the system.
Installed the Service Pack 3 from Microsoft to my Win XP and defragment the HD again. Also failed to fix the problem.
And at last I came across a forum with a similar problem that was fixed by removing the two 1Gb dimms from a Asus MB (also with 775 socket) and leaving just one. But to me it did nothing when I removed the three 1Gb Dimms from my board…
- My next move will be to install Windows XP 64 bit Edition SP2, but the 32 bit XP sould be working !!! So I’m gonna wait to read some comments before I do this.
I don’t know what else to do. I really hope someone can guide me on how to fix this problem !!!
Thank you very much in advance for and post and also I apologize for my bad english ![]()
In case it’s necesary or needed, here is my HiJackThis report:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 11:59:04, on 11/09/2008
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\Program Files\Microsoft SQL Server\MSSQL.2\MSSQL\Binn\msftesql.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\Spyware Terminator\sp_rsser.exe
C:\Program Files\Microsoft SQL Server\90\Shared\sqlwriter.exe
C:\PROGRA~1\AVG\AVG8\avgemc.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\MSN Messenger\usnsvc.exe
C:\Program Files\BitLord\BitLord.exe
C:\HijackThis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Live Search
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = Live Search
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL
O3 - Toolbar: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL
O4 - HKLM..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM..\Run: [TrojanScanner] C:\Program Files\Trojan Remover\Trjscan.exe /boot
O4 - HKCU..\Run: [msnmsgr] “C:\Program Files\MSN Messenger\msnmsgr.exe” /background
O4 - HKUS\S-1-5-19..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User ‘LOCAL SERVICE’)
O4 - HKUS\S-1-5-20..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User ‘NETWORK SERVICE’)
O4 - HKUS\S-1-5-18..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User ‘SYSTEM’)
O4 - HKUS.DEFAULT..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User ‘Default user’)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra ‘Tools’ menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O20 - AppInit_DLLs: avgrsstx.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: AVG Free8 E-mail Scanner (avg8emc) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgemc.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Spyware Terminator Realtime Shield Service (sp_rssrv) - Crawler.com - C:\Program Files\Spyware Terminator\sp_rsser.exe
End of file - 4446 bytes
Ok… Now as you can see my Pc is clean as a whistle in spyware and viruses stuff.
Less than a week since last reformat, antivirus and antispy since the 1st minute of the reformat and now is fresh from the Spyware Removal Guide By Osiris: Updated 8/18/2008, did it last night.
My HiJackThis report show nothing to remove ._.
Guys… I’m think this rules out any software issue as the cause of the symptoms, pls..
I’m desperate to get this problem fixed
What kind of problem persist even after several reformats?
._.
I guess a hardware problem…
Is there a techy out there that has seen anything like this before?
