My pc keeps freezing
i have pentium 4 2,26 GHz 512 MB ram
Most of the times i start my pc and it freezes after a minute or two :frowning: ..
after that i cant do anything but sometimes i get a screen with lower resolution and the lowest color quality or the pc starts beeping until i restart it manually..
everyday i have to restart it about 2-4 times until it stops freezing and i can use it the whole day after that..
i tried everything and i guess it must be a hardware problem..
any ideas??
Firstly, I would make sure your RAM is in the slot all the way. Secondly, you may want to download and run memtest to make sure that your memory is fine.
ok i’ll try it thx :slight_smile:
hmm i think it was the ram .. my pc seems to be working fine till now.
i have a free slot for the rams, does it matter if i moved one ram to this slot?
Yea you can try putting your RAM in another slot.
yes fred that’s it thx :good:
