Ubuntu is a great distribution but requires a reasonably modern computer. I wouldn’t want to run it on anything less then a 500MHz, 192MB of RAM spec computer.
So what if I wanted the power of Ubuntu and the ability to run on an original Pentium or K6-2 with only 64MB of RAM? Well, i’d have to look at replacing GNOME, KDE or XFCE wouldn’t I?
Last night I did a ‘server install’ of Dapper Drake. Only the base system got installed, no X, no Window manager or X programs. Once it had finished, I was greeted by a rather plain command prompt. From here I was able to configure the network and add the Dapper Universe and Mulitiverse repositories. Then I customised my installation by installing x-core-system-files and iceWM.
Once that had finished, I decided to add a few more bits before I booted into X for the first time:
ROX-FILER
Endeavour2
Xarchiver
Firefox
Evolution
GAIM
GXINE
XMMS
Various Audio & Video Codecs
gtk-theme-switcher
Aterm
Mousepad
nedit
GQView
xpdf
xpaint
Various IceWM control panels and extras.
As you can see, I decided to keep with the ‘light application’ theme. Choosing AbiWord over OpenOffice, XMMS over Amarok and Xpaint over the GIMP.
I rebooted my computer and logged in. Then I held my breath as I typed ‘startx’. When iceWM finished initialising, I was greeted by a rather plain looking desktop. iceWM isn’t known for it’s looks and most of the themes are horrid.
But that’s not the point I here you say? iceWM is supposed to be a light window manager, nothing else?
Well, I found an absolutely gorgoeus Ubuntu theme for iceWM. To look at it, you would not believe I was running iceWM. It just looks awesome.
All that was left to do was change the rather ugly GTK themes using GTK-theme-switcher, and hey presto, I had some serious eye candy for such an old computer!!
I’ll post some screenshots when I get home and maybe a mini tutorial.
EDIT: On a side note, I am really impressed with ROX-Filer. Some of it’s default settings are a bit off (like the automatic Window resize), but once it’s properly configured it’s great! ![]()
