Need a psu advice
im planning to buy 8600gts
was wondering if that psu is good for it
http://www.lc-power.com/images/upload/pdf/power_109.pdf
looking all good to me according to the wattage supply it has written on it…but i havent heard of this brand name.
To get some information on PSU’s, you can check [link=http://www.hardwareforums.com/power-supply-sticky-5218/]this thread[/link].
I don’t know if LC Power is the same as L&C, but L&C seems to be grouped with such brands like Deer and Allied, both bottom tier PSU brands.
im not sure if lc power is l&c
but that lc power 550w will cost 50 euro a bit cheap than other prices
normally a good model of 400 will cost about 70 euro
but it looks good so i dont know what to do
yeah
A good PSU in the 500-550W range runs anywhere from $80-100 in US online shops in most cases. If you need to save some cash, Hiper or FSP would be your best budget options for a solid PSU.
It’s worth the money to purchase a good PSU. A bad PSU can damage and/or destroy hardware and cause instability, not to mention being unable to deliver the advertised wattage within reason. The up front cost is less, but it could ultimately cost you more in the long run. The power supply is a major factor in system stability and performance. If your parts can’t get the juice they need, they may not run at full speed.
Buying high-end parts and putting a cheap PSU to save money or otherwise is like buying a Ferrari and putting regular in it because the premium it requires is too expensive. You won’t be able to enjoy your upgrade if it’s crashing or slowing down when you use it.
You don’t need to buy a 1000W PSU, but a capable unit that won’t cut corners is a must. One of the worst ways to save money is by purchasing a crappy PSU. Go with a slower card, a little less RAM, a slower CPU…just don’t skimp on the PSU.
great information thanks
what u think about this psu for 8800gts
http://www.antec.com/ec/productDetails.php?ProdID=07643
im not sure if it is a bit low as it is good mark
The specs look decent. The only thing that worries me is that the 650W version of the Trio line doesn’t actually have 3 separate +12V rails, which is the buzz with the Trio name. I don’t know if this applies to all the Trio’s, but it is something to be aware of. If the +12V rail is giving you 30A or more, you should be fine.
well finally i went to the shop today they said that be quiet is really good model this is the link
http://www.be-quiet.es/pdf/straightpower_500_en.pdf
thanks for helping me in that every 1 :slight_smile:
