So after checking out many items, many cases, and so on I decided to go for a small footprint mATX case, that is clean and can support the items I need.
Anyway this is the build I came up with:
Case:
Ft03 silverstone silver
PSU:
Seasonic X660 Modular
Motherboard:
Asus Maximus IV Gene-Z
CPU:
i5 2500k
GPU:
Asus GTX 570 direct cu ii
CPU Cooler:
Corsair H80
Memory:
Corsair Vengeance 1600mhz cl8
HDD:
Samsung F3 1tb
SSD:
OCZ Vertex 3 60gb
Price: 1500 dollars
Consider that the Prices in my country are higher so, if bought fully in the US for example all parts its about 1000-1200.
Questions:
Good build? should I change something?should I replace the case fans?H80 fans?How far do you guys think I can OC my CPU?
Thanks Alot!
Harlequin
