Need help adjusting OC settings please
Hi
I have a PC that has been overclocked.. The machine is ..
Intel Core 2 DUO E6600 2.40GHz @ X6800+ 2.93GHz Dual Core SILENT DDR2 System
The PC has 2GB of RAM and I’d like to add an extra 2GB… I’m told I need to remove the overclock settings and install the RAM then re-adjust the overclock settings after. I was hoping I could get some help with this? The following link will take you to 2 pictures of my BIOS settings (all the relevant settings are there I hope)
.Mac - iDisk
The original RAM timings (factory) are 4 4 4 12
If you could tell me what I need to change it back to before installing the RAM then what it should be after I’d really appreciate it.
Thanks
Jon
