Need help badly, Radeon 9550 doesnt work..
So from the top. i’m a newbie to hardware so be gentle please..
I am trying to install a Sapphire Radeon 9550 AGP graphics card.
I’m using an ASUS A7N266-VM rev.1.05
Bios rev ev 1005 (not sure what this means but might be useful?)
My motherboard has an NVIDEA GeForce 2 Integrated GPU which i have a driver installed for.
Right so, got the card, put it in the AGP slot, well seated, plug in my monitor cable and i got no signal. i’m not even sure my HD is spinning up because i get no bleeps and a “no signal” message from my monitor.
Removing the card and going into the bios i change the primary graphics whatchamajig to the AGP slot, plug it back in, still no joy.
i’ve tried pre-installing the driver for the Radeon and disabling the NVIDEA driver but that doesnt work either, running out of ideas.
Welcome to HWF :slight_smile:
Is the Radeon card detected in Windows (visible in device manager)?
Open device manager and right click your old integrated video device. disable it. restart with the vga/dvi in the 9550 and it should work.
firtly, i cantget TO device manager with the card in, as i cant even get past the bios.
and yeah, tried disabling the integrated card both using device manager and the bios
