I built a new computer for a video editing system using the supermicro P4SCT+II MB. I have a P4 3.2 / 800FSB cpu and Kingston PC3200 ram (2 x 512).
When I power up the system I’m getting no video output and the standby LED (on the MB) remains on. The harddrive sounds like it’s starting up and the CPU is warm (so I assume it’s working). I’m hearing no beeps and I let it run for a few minutes with no change. I have tried installing the RAM in both DIMM 0A/1A and 0B/1B.
I have removed all cards and swapped in different RAM from another computer, and tried an AGP video card and the onboard VGA, no change. I have gone over all jumpers all look good.
I talked to tech support and exchanged the MB but the same thing is happening with the new board too.
On the side of your powersupply there will be a white sticker, this will state the Ampage that your powersupply can provide to each Voltage Rail. Ampage is alot more important than Wattage, Wattage is merely a measurement of the total max power available to the system.
If you could possibly post back with the details of your powersupply’s Voltage Rail information, this would greatly help in diagnosing your problem, also if possible a full specification of your computer and whats in it:
Manufacturer / Model / Speed e.t.c
Personally I would either say that your powersupply is not powerful enough, however more information will help us determine this.
I realise you said that you have checked all your Jumpers, have you cleared the CMOS?
Thanks, here’s the power supply specs…Output: +3.3V@15A, +5V@35A, +12V@17A, [email protected], [email protected], +5VSB@2A (450W total). It’s a MGE Vigor450.
The CPU is a p4 prescott.
Harddrives - WD 80g, 2x WD 250g SATA.
I have tried the onboard VGA and a NVIDIA GeForvce video card (which I pulled from my other computer, so I no it works)
Yes clear the CMOS, but make sure that your computer is turned off and there is not power connected to the computer.
Then try and turn your computer on, if it does not work then you need to get a new powersupply, i doubt clearing the CMOS will work, as by the looks of things your powersupply is a generic powersupply. The ampage on it doesn’t look very good at all. Especially if you are running 2 x 250GB drives 1 x 80GB, a prescott, graphics card.. e.t.c thats quite abit of power consumption..
If the CMOS doesn’t work, disconnect all connection / power cables to your 2 spare 250GB hard drives, graphics card (use your onboard) and see if that works.
12V ATX 1.1 is a requirement for a certain level of power expected from the PSU, as for the standby this means that your computer requires 1amp of power just to run in standby mode..
I would try a more powerful powersupply if possible, also what overall wattage does your powersupply supposed to do?
my PSU is rated at 450W. I read all kinds of good reviews on it before I bought. If needing a ATX 1.1 rather than a ATX make a difference I’ll order the right one.
OK…I figured it out. When the reset switch is plugged in, the board doesn’t work. I powered up the board out of the case and it worked, so I re-installed it, powering it up after every connection was made. It worked until I plugged in the reset switch. :rolleyes:
Must be a bad switch or wire I guess. P-I-A! :mad:
Special thanks to supermicro tech support who kept telling me to return the MB and CPU because they were bad. :mad:
That’s the first time I’ve seen that particular problem, and I think, while it obviously does happen, the chances for it are pretty low. Just goes to show you that it’s a good idea to test the board outside the case first.
