Need help frustrated!!!
Is there ANY replacement with higher wattage (500 watts?) for the 240 watt hp power supply thats onboard the compaq 6000 pro smallforms? I can’t find any and from what I understand I might have to modify the connection (its proprietary to hp) to get any replacement.. Is that the case or is there one I’m missing that will work with hp’s proprietary power supply? The part number is 503376-001 and I hope I don’t have to jury rig the thing just to get a better supply in there..
I heard that it’s impossible from one guy, another said you can get an adapter that would allow an off the shelf power supply to work.. IDK and I just want to get a graphics card in there!!!
Help me out please.
Hi and welcome to the forum.
Are you sure you need to change the PSU? Are you having power outages?
Have a look here -
HP Compaq 6000 Pro Small Form Factor PC specifications - HP Small & Medium Business products
Under graphics it is showing support for one mother of a graphics card (among others…).
Looks to me as if the rig should work using the OEM PSU. Then again I may be wrong… :x:
