Hi I’m looking to buy a new system and found a place after looking for a month that will build to my specs and the systems dont look like every one else. I called and they said they would install a water cooling kit a i have to do is pick from the inventory anything.Also all there systems come with black drives and rounded cable and 3 or 4 led fans every were else charges you for that stuff. Free shipping to.OK this is what i’m looking at.
MSI K8T800 NEO-FIS2R 800FSB DDR400 Audio/GBLan SATA 5 PCI
AMD Athlon 64 3400+
eVGA GeForce 6800GT 256MB 8xAGP TV-Out
512MB DDR400 SuperTalent Gamer RAM CL2
Maxtor 120GB 7200RPM SATA 8MB
NEC DVD±RW ND-3500A 16x Dual layer Black
Artec 52X24X52/16X Combo CDRW/DVD Drive Black
Creative Audigy 2 ZS 7.1 THX 24bit
Creative T5400 5.1 Surround Speakers
Matching Keyboard/Optical Wheel Mouse Set
Sidewinder Case Red/Black w/400w PS
Windows XP Home (With CD)
http://www.addictpc.com/index.php?crn=125&rn=2109&action=show_detail
OR
http://www.addictpc.com/index.php?crn=457&rn=977&action=show_detail
thread moved
Nothing personal, but the introduction zone isn’t the general hardware problem and there’s no need for two threads covering the same thing.
Thats a S754 mobo which means that you won’t be able to upgrade without changing your mobo. If you wait you can get a S939 PCI-E mobo which you can get with a 6800 pci-e and allow for further upgrades.
or you can be as impatient as me and just buy a 939 board without pci-e
In terms of the hardware… I think that moving to the Socket 939 would be a better idea. Having upgradeability in this day and age is pretty important with the constant turnover with processors and video cards.
I don’t see AMD making another socket change any time soon, so if you get a socket 754 now, you would not be able to move to an FX series if they drop the price or are greatly improved.
It seems as though the specs will make a pretty powerful system, however, I looked at the AddictPC’s website, and they don’t really offer a very good warranty or support. One year warranty on retail/boxed items? Manufacturer warranties are 3-5 years. Just my two cents.
