Hey all.
I recently went out and bought me a AMD 64 3200 and a Asrock 939s56-m motherboard. came home put it in, came to turn the pc on and nothing happens the cpu fan spins so does my other fans. no beeps nothing.
can some one tell me whats wrong and if theres a way to fix it?
thanks.
What are your other specs? (RAM, GPU etc)
What Power Supply are you using? Have you made sure to connect all the power connectors to the motherboard?
ahh thanks one of the cabels was hidden behind my hard drive durrrr:mad:
thanks for your reply anyways.
It’s cool, sometimes it’s the most simple thing causing a lot of hassle.
