I installed new nvidia drivers and restarted my computer. I dont get to the desktop. I get a box that floats around my screen saying "not optimum mode, recommended size then says a resolution. Tried resetting CMOS and that didnt work. Please help because this would be the 3rd computer that has to get repaired if i dont fix it before my dad gets home.:swear:
It’s not a bug. What the new drivers are doing are allowing you to set an optimal resolution based on the monitor in use. Just Hit yes/OK when the box pops up.
It doesnt give me a Yes or no option, it just has a box floating around saying not optimum mode almost looks like a screen saver.
Can you not just rollback the driver?
I can’t get to the logon screen which means i cant get to the desktop. ![]()
safe mode?
Nope, tried that and the same thing happens at the same time.![]()
bump/
