need some advice
I’m wanting to upgrade my computer. I just recently intalled norton 360, and now my computer runs very.. very slow. It has an AMD Sempron 1.3Ghz and 1 stick of 256MB RAM. There is only one more slot for a stick of ram to go though. Would gettin another stick a ram do the job or am i better off just gettin a new motherboard, cpu, ect..?
Really the only things i do on this computer is surf the internet and play warcraft 3. Ever since i installed Norton, though, war 3 will barely play. I need norton as for i do my all my bills online as well.
Hi, yes another stick of ram can make a difference if your motherboard supports dual channel configuration. Reason why your system is running slow is because alot of anti virus programs do use alot of memory bandwidth and in your case your running single channel configuration is even less performance. I would recommened upgrading your ram from 256mb to atleast 2GB. post your motherboard make and model and we will advise you on what ram to buy. we will select appropriate memory bus speed and memory capacity.
Me and my buddy built this computer 4+ years ago. It has a MSI N1996 motherboard, Radeon 9200 AGP 128mb, a 40G ps2 hard drive lol(maxtor), and a samsung cd drive/writer.
Hi just had a look and your motherboard supports a maximum DDR 266mhz PC2100 ram upto 1GB and it doesn’t support dual channel. so the maximum you can get is 1GB and the highest speed it can handle is 266mhz. so you might as well get rid of the 256mb stick and invest in 1gb stick.
PQI 1GB (1024MB) PC2100 DDR 266MHz CL2.5 Memory - eBay (item 250421575195 end time May-16-09 10:07:09 PDT)
if you don’t do anythin but browse the web and play war craft 3 then no point in buying a new system.
Hi,
I’m Melinda and I represent Symantec.
I would be happy to connect you directly with Symantec Customer Service if you are still having this issue with your computer and Norton product.
Please send me an e-mail with your full name and best contact number to reach you.
Regards,
Melinda
[email protected]
Melinda (MelfromSymantec) on Twitter
Yeah thats what i figured. I wanna do this as cheap as possible. We have another computer in the other room that is much faster and has vista (just bought it), ,but my wife hogs it lol. It ran fine before I installed norton and really all i want to do is make up for what norton has taken away. Thanks for all your help. :slight_smile:
I have 2 slots for ram.. you mean to tell me one of them is more or less useless??
yea because your board supports maximum of 1GB and your going to buy a 1GB module so one slot will be unused, and it doesn’t support dual channel so no need in buyingn two sticks of ram.
So if i buy 2 512mb sticks of ram my computer will only use 512mb of ram? That’s just dumb as h*ll, then again i believe the motherboard only cost me like 18$$ back in the day.
no it will still access both modules of ram but you will not benefit having two 512mb modules of ram because your motherboard does not support dual channel configuration. so what im saying is you might as well buy one module of ram @ 1gb.
True, but two 512mb sticks will most likely be cheaper than one 1gb stick, and both will provide the exact same performance. Either way, you’ll probably only be spending around $20, so you can’t go wrong.
Ok guys.. due to my cash flow i wasn’t able to buy that exact stick of RAM. Now i have the money :chk:.. So will this work for my comp? 1GB PC2100 DDR 266MHZ 184pin ECC 184Pin DDR RAM Memory - eBay (item 150340933595 end time May-22-09 17:01:04 PDT)
Or should i look at a different brand or different specs? Thanks in advance
Or even if you could direct me to a better one and/or one that will work with my motherboard around 20-30$$???
