Need some help here guys. I have a asus a7n8x delux motherboard, amd athlon xp 2500+ proc overclocked to 2800+ curently running at 2.08 ghz. Also 1gb of ddr 2700 333 fsb ram and western digital 40 gb hard drive. I would like to know if a msi geforce 6600gt would run good with my spics as above. Any help would be appreciated. Thanks shep1342
yep. Would run good. Only thing holding you back majorly would be your RAM speeds and Latency timings, other than that you’re good
However with an AXP 2.08 it would also be a bit of a bottleneck for the 6600GT aswell as the RAM.
[QUOTE=ninja fetus]
Thanks guys. So now I will get 3200 400 fsb ram and increase my 2500+ cpu to 3000+ cpu. This will make my pc run better right. So if I done this over clock think she would run the 6600gt efisiantly without hangups or not.
:good: Thanks guys took your advice bought msi 6600gt, got some new ram 3200 400fsb overclocked my amd 2500+ to 3000+ 2.104 ghz. Got a good copper heatsink to keep her cool. Now on 3d mark 01 se I get a score of 15319. Also get a score of 8070 on 3d mark 03. Now I can play most of my games on high setting. Great setup and works asume.
glad it works ![]()
