I just need to change the design a bit and then it should be ok!
Big B could you send me all the articles? with all the pics, in html / txt format, so I know where the picture goes!
thanks allot
the process is slow while I fully figure out how to use this script, but I’m getting there!
I’ll have to do some work on a few, but most are done. I’ll instert the image tags where the image should go. They may need some adjusting to better suite everything, but it should be ready to go.
I’m looking forward to the new stuff.
