Nero Buffer Issue
When using Nero Burning ROM to burn normal Audio CD’s, the buffer goes to about 99-100% and then gradually drops to 0, then it gradually goes back up to 100, and repeats. I’ve tried burning the discs at lower speeds, still doesn’t help. When I play back the CD, it often skips a second here and there, I think its connected with the buffer issue. Is there a way to keep it hovering at a high %? Thanks in advance.
are you doing anything other than burning?
How fast are you burning the CD’s?
[QUOTE=ninja fetus]
Nope, AV and everything is disabled during my burn process.
[QUOTE=pelvis_3]
I’ve tried it at 52x, I’ve tried it at 4x, still the buffer goes to 0.
I’m going to try NTI CD/DVD Maker, and see if the buffer goes on that too.
UPDATE
It seems that it’s a problem with nero, because we get the same problem at work, the buffer depletes itself, and the audio skips.
I’ve tried using NTI CD/DVD Maker, and the buffer remained near 100% the entire time. I’ve lost respect for nero.
