Netgear
I have a Netgear Wireless router and works fine
Just it seems to be stopping me from peer sharing using Win MX and Sharaza.. Not sure how to change the settings to allow this..
It does not say anything about blocking them
Please help
It’s because of the firewall, built in to the router.
There are various ways of connecting to the servers, but these involve connecting to another system, and gets a little too dodgy for my liking.
There must be away around it
Each p2p may be different. Check with any documentation. You should be able to enter access the router with its ip address and then going on from there. But I’m not totally sure.
Its WinMX Im using
Any ideas how
You may need to check WinMX’s settings for what socket and/or port settings you want to use. Additionally, you may need to manually open a port through the router to make it work. Specifically, I don’t know how, so check the manual for the router. I’ve used WinMX before, but it’s been so long, I can’t remember the specifics of it either.
Gald to Tell everyone that i have sorted it out no
I had to change the firewall rules to allow the traffic…
But i was using the wrong IP number
Thanks for your support
glad you got it fixed :slight_smile: I also have a netgear router had some problems when I got it, you may want to upgrade the firmware, just to keep it upto date.
iv got a Q-tec router and everything works fine and i hope it stays that way but i would’nt trust the routers firewall alone m8 :good: Dave
