I have a wifi network on my old computer. It tramsmits with a wifi dongle. Can i pick this up on my new homebuilt PC?
If your new homebuilt pc has Wifi or a wifi dongle then probably, yes. You would have to be within range of the laptop, and your computer would need setting up with wireless networks.
How does my computer have Wifi?
Some motherboards come with integrated wifi, and if so will be able to connect to a wireless network. Your computer may or may not have this.
how do I check this?
If it’s a homebuilt PC, you’d probably know about it. If you are using Windows XP, you can check by going Start > Settings > Network Connections (in classic start menu) and wireless connection would show up under there.
it doesn’t so what do i need to buy to be able to pick up a wifi signal? and around how much will it cost?
Thanks
Something like this would give your computer WiFi. Also this would give you Wifi, but it connects via USB and can be removed and put into other computers easier.
Hi Thank you but i just want to make sure of something. I have a WIFI connection not a WLAN, will this still work?
WLAN (Wireless Lan) is the same as wifi.
Do you have a wireless network router? If not, then you should still be able to connect your laptop to your computer, but it will be a bit harder.
Also, have you considered connecting them by cable?
