hi i just built my own pc and am having problems adding it to my network can anyone tell me how to add this pc to my network please?
HDFK
HDFK
Well what have you tried?
Have you pinged the other computers?
Have you ran the network setup wizard?
Which OS are you using?
Are you using a Hub, Router or Switch?
We are going to need this info!
[QUOTE=pelvis_3]
ok sorry, i treid the network setup wizard but it couldnt find my ROUTER (Gateway) im using xp home editon and thas the inof!
go to RUN and type in command, should take you to a DOS like screen and try typing in
net view
and find your computers network name
then go to another computer and do RUN command
and type in
ping
then give a space and try to type in the network name
see if the ping data packets get a reply
