Here goes i have been given a hub which as 25 RJ 45 sockets on it so i connected my virgin media modem to this hub and then from the hub to my pc and it worked so i then connected my second pc to the hub but i am not getting the internet on it can anybody help please.
[QUOTE=Addis]
If its a hub, then it won’t have routing abilities. To share internet you’ll need a router.
:doh: should have known that, i did have my router going to a hub / switch to attach my ATA (VoIP) adapter, until i over powered it by using the wrong PSU:doh:
[QUOTE=megabytes]
The cable i’m using is the straight through type is this the wrong cable???
if i remember correctly a straight though cable will be fine between the systems (i used a straight through cable to connect my router to a system) & the hub but Addis is correct about attaching a router to 1 port of the hub, then allowing 24 systems access to the net through the hub
