New Build need advice
So basically I’d like to get a feel of how much of an upgrade this would be. I’d also like to know how well games will run with this new build.
Here is my current computer:
Dell Dimension E520 Product Details | Dell
Specs I bought:
CPU: CoreTM 2 Duo processor 4300
OS: Windows XP
RAM Memory: 1GB (Now 3GB)
HD: 150GB
Graphics: Onboard (Now Geforce 6800)
Sound: Integrated/Onboard
Things I added:
450W PSU
Couple extra fans
This is my new build:
PSU: Newegg.com - hec X-Power Pro 650 650W Continuous @ 40°C ATX 12V v2.2 / EPS 12V SLI Ready CrossFire Ready Power Supply
CPU: Newegg.com - AMD Phenom II X2 555 Black Edition Callisto 3.2GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Desktop Processor - C3 Revision HDZ555WFGMBOX
Mobo: Newegg.com - ASUS M4A88T-V EVO/USB3 AM3 AMD 880G HDMI USB 3.0 ATX AMD Motherboard
RAM: Newegg.com - Kingston HyperX 1GB 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory Model KHX8500D2/1G (2 of these)
HD: Using one from Dell PC
Graphics: Newegg.com - HIS IceQ H567Q1GD Radeon HD 5670 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
Also using some other parts from the dell such as dvd drive.
Thanks for your advice!
Sasa
Are you still going to be using Windows xp or are you making the jump to 7? also why don’t you go for a ddr3 mobo and ddr3 ram to future proof a little bit?
I plan on using Windows XP. I’m on a really tight budget as well. But how much of an upgrade do you think this would be compared to my current PC?
winxp wont make use of ram more than 3.2gb and xp boot times suck in general.
but the upgrabes would be beastly on these specs fo sho
i recomend 4gb ram and windows 7
Well after hearing that I’ll definitely switch to 7. What’s the max ram windows 7 64bit recognizes?
