mobo: ALiveNF6G DVI
CPU: AMD Sempron 3000+
RAM: Kingston 1GB & Kingston 256MB
Graphics Card: I can’t find the Specs for this but it’s got a DVI output
Monitor: Plug ‘n’ Play (with/w/o DVI adaptor)
O/S: Windows Vista Premium 64-bit
I bought a new AMD Athlon 64 yesterday morning and installed it. It ran great from all signs of the fans and beeps. problem was that the monitor gave a “RGB no signal” message. I tried a TFT monitor, and that gave the same thing.
Now my PC will turn on, all the fans working, usual beeps, and then it dies after about 2 seconds. I have swapped power sources to no avail. I put my old CPU back in and it runs fine, with no cutting out. except for the monitor still doesn’t work.
I have tried reseting the CMOS battery, i have cleaned all my RAM/Graphics. Made sure the CPU is seated properly. Nothing seems to work.
I have just (again) replaced my old CPU with my new one and it now runs without cutting out. So i guess its just the monitor problem so i can see what it’s outputting…
I’m trying it on the TFT monitor through the DVI graphics card now but where i would normaly get a no signal message it’s just a black screen at the minute.
EDIT: it’s giving me the no signal message! (it’s an old monitor and needs to warm up)
I took it to my knowledgable friend and he had a look. a few of the pins on the CPU chip were slightly bent! a few nudges later and i’m up and running perfectly and using it right now to write this! :chk:
