For all you that are looking for a new power supply that is cool and is functional then check out this new one
Ultra ULT31556 X-Connect 500W ATX Power Supply
I just out my little hands on this one like 2 hours ago.
I just put in a case that i am building for a freind. It is asome so easy to use and the wires in this thing are cool to take a look that this link of the pictures
http://www.hardcoreware.net/reviews/review-231-1.htm
it is easy to install and it works really good it also is not that loud.
I suggest that if you are looking for a new power supply get on of these
They run around $100 and they have different types with lights in them if you are in to that stuff. Those run around $130
Hey, that’s pretty rad! Looks like they forgot to include the rated power rails in that review, so here they are:
AC Input: 115V/230V 10A/6A 60/50Hz
DC Output:
• +3.3V – 28A
• +5V – 30A
• +12V – 34A
• -12V – 0.8A
• -5V – 0.3A
• +5VSB – 2A
Not incredibly impressive specs, especially compared to Enermax. But by the sounds of the torture tests they subjected it to, it sounds like the power it is providing is clean and solid.
