I installed two 1GB OCZ DDR2 (model OCZ2SOE6672GK) RAM sticks into the remaining two slots available. The other two slots contain two 500MB OCZ DDR2 (OCZ26671024ELDCGE-K) RAM sticks. As per the instructions in the manual, I made sure to install similar RAM sticks on channel 1 (slots 1 & 3) and channel 2 (slots 2 & 4). After doing so, when I press the power button, as soon as I let go, the computer turns off. If I press and hold the power button I get one beep but no signal is sent to the monitor and it remains in power save mode.
At one point it turned on but it failed at the IDE scan with the following message:
“Error! Firmware not ready.”
One other time it powered on correctly and got past this error message only to have it fail when trying to find a system disk.
Troubleshooting already attempted:
Check cabling (IDE, power)
All combinations of RAM:
-revert to old RAM
-remove old RAM only use new RAM
-use both but in different slots
Disconnect one or more IDE cabling
Rearrange IDE cabling to go to different slots
I’m at a loss as to what to try next. Any help would be greatly appreciated.
System:
Model Name : GA-8I945G Pro
M/B Rev : 1.0
BIOS Ver : 1.7?
Serial No. : 50537500668
Purchase Dealer : newegg
VGA Brand : Model :
CPU Brand : Intel Model : Intel Pentium 4 530J Prescott 3.0GHz LGA 775 Speed : 3.0GHz
Operation System : Win XP SP : 2
Memory Brand : OCZ Type : DDRII
Memory Size : 1GB 2x, 500MB 2x, 3GB Total Speed : 677
Power Supply : 450 W
IDE1: 2 DVD R/W Combo Drives
IDE2: 2 120GB HDD
IDE3: 1 80GB HDD
Expansion Slots Used:
ATI D33053 PCI Graphics Card
Case:
RAIDMAX X1 TX-909WBP
Power Supply:
Set to 115V
