new sound card
I just got a new sound card.
I connected it to the pci slot and installed the software and i still have no sound. I posted before about trying to get the onboard sound to work but it never did.
Am i supposed to connect some wires as well as the pci connection? the manual said connect the cd-rom drive audio wires, but i didnt get any wires with it??
I am considering wiping my hdd and reinstalling windows.
Any ideas?
specs.
amd 64 dual core 4400
1024mb corsair ram
250gb hdd seagate barracuda
philips dual layer dvd burner
6800gt
600w psu
You need an audio pass through cable. Here is a link:
http://cgi.ebay.co.uk/TWO-CD-DVD-AUDIO-CONNECTOR-CABLES_W0QQitemZ5833932100QQcategoryZ31492QQrdZ1QQcmdZViewItem
You shouldn’t need those cables. Thanks to the design of the ATA standards, sound can be transmitted over the data cable without the need for the pass-through cable.
However, something is amiss.
The easiest stuff to check would first be that there’s no conflicts in Device Manager.
If there is no conflict, check that your speakers are plugged in the right ports, turned on, and that the sound on your soundcard isn’t (for whatever reason) muted in Windows.
naa, fixed it, just had to turn off the onboard sound in the bios, sound card is working now.
Ah, yes, that’d cause some problems too.
