Just wondered if anybody knows where i can get my hands on a basic guide to Kubuntu? (I mean very basic, as in tell me exatly what to click and when to click it )
I am not getting on to well. Have run into loads of problems, and to be honest i donât have a clue how to anything on there. I feel like such i prat :doh:
I Have a long list of questions but before i ask you guys i would rather see if i could fix them myself without bugging you.
I have had a look at the stickys but even alot of that stuff goes over my head.
[QUOTE=shortcake]
[/quote]
just ask, if i think back, iâve asked some stupid questions myself (and still do) no question is a stupid question, cos if you donât know something, you donât know
how else are you going to learn, just ask
[QUOTE=shortcake]
[/quote]
go ahead, ask
I understand that Ubuntu is pretty much the same animal as Kubuntu - the main difference being that Kubuntuâs default desktop is KDE and Ubuntuâs is GNOME.
The KDE desktop seems to generally be preferred to GNOME as it it said to be more powerful (I would go along with that thought).
In any event - just ask on here if you have questions. Remember - everyone has to learn! Theyâre a great bunch on here and will always be happy to help if they can.
[QUOTE=David]
thats the only difference, bassically if you uninstall Gnome from Unbuntu and install KDE, Unbuntu becomes Kubuntu, and i presume if you replaced KDE with Gnome on Kubuntu, Kubuntu would become Unbuntu
Thanks DavidNW for the book Link. Might have a look into getting that.
I think the problem with me is, if it doesnât work first time, i loose patience. ( I think thatâs why me and Windows donât get on to well)
If i go back later on i can usually fix it lol
So as Donkey said i should do i will list the problems i am having. Please help if you can guys but i accept that i can be quite annoying lol
SoâŚ
In windows you have a device manager where you can check if you have upto date drivers. Is there something like this in Kubuntu? I think this would solve alot of my problems like my CDâs not playing and also working out how to set the printer up.
I donât understand about all the commands. I understand i can type " kdesu kopete " in the run command to run Kopete. But i donât understand much about running things in the other one. The terminal sessions i think?
I also donât understand the levels of access. Like Sudo and things like that?
Also somewhere along the line i would like to install the Beryl stuff with the effects. But at the moment running before walking comes to mind Also i think that that would tie in with the drivers section to make sure i have got the correct ones.
One last thing until i think of some more. I dont have a clue how to download things. I think they download fine but installing them is another matter. I cant even play my Penguin game on here that i love due to me not having a clue how to install adobe player!
Thanks guys for helping me out. Would not of got this far without you
Okay, letâs start with some basics. Above all, donât try to rush yourself learning all - because you wonât. Iâm a complete newbie, so canonly give you limited advice.
However, take one thing at a time and just ask as you go - people on here will only be too pleased to help if they can - remember that!
A good starting point would be to check out this thread:
It will give you information about setting-up your software repositories. Once these are set up, downloading and installing programs is a breeze via the package manager which you should find on your desktop under âApplicationsâ.
You should easily be able to install Adobe player by the aforementioned method once you have set up your software repositories. So, once, again, check out the link and get those repositories set up (if you have not done so already). Your install of Kubuntu probably came with a âdefaultâ repository list and would, of course, have allowed you to download and install programs. However, the repositories mentioned in the above link are likely to be far more extensive and will provide you with a great choice of various programs.
Hmmmmm, thatâs a strange one. I just typed the code:
kdesu kate /etc/apt/sources.list
in a terminal window, was asked for my password, put it in, and up popped the repository list!
Okay, letâs try this another way:
Type: sudo su
in a terminal window - hit return, then type: kdesu kate /etc/apt/sources.list
Hopefully the repository list should pop up for you (well, just tried it and it did for me!)
Note: the repository source list should pop up in a seperate window.
EDIT: your post saying you got an error when you typed in the code for the repositories source list seems to have gone from view - hence the above reply by me.
I think thatâs basically it - thatâs how I would see it. However, you might want to pose the question in a seperate thread to be absolutley sure, as Iâve not added to a source list file yet.
I suppose, in any event, if the code you copy over for the drivers does not work - you can always edit it out and save the changes, then youâre source list file will be back to how it was.
You should look at the âLinksâ section of the âGetting the most from Ubuntuâ thread. You will find links covering installing multimedia codecs, software installation, windows file sharing and 3D beryl effects.
There are 2 main levels of access in a Linux system. A normal user and the root user.
A normal user is the user account you use to log in at the login screen. This user has limited privileges, they can run most programs but cannot make system wide changes (more specifically, they canât make changes outside their home directory, which is a bit like the Documents and Settings/yourName folder in Windows). The default home directory is /home/username. This is the place where all your personal settings are stored. E.g. when you add a new firefox bookmark, then the changes are written to a hidden folder /home/username/.mozilla.
The root account is the administrator account. This account has privileges to do about anything they want. This is used for system administration, and if youâre not careful with it you could end up breaking your installation. Thatâs why you run as a normal user for day to day tasks (you canât screw up system settings that way).
Ubuntu and derivatives behave differently to normal distributions. I donât like the way theyâve changed it, but its meant to be more user friendly. Basically, whenever you want to run a program or command as the root user, instead of doing this:
su
enterrootpassword
you now instead do sudo command to run as root user.
Theres also one thing you need to remember, if you want to run a graphical program as root, then you need to do kdesu commandor gksu commandYou shouldnât use kdesu, gksu, or sudo to run any programs like Kopete or Firefox. They should only be used to run programs when you need root access.
Yeah but using sudo IS more secure then using su. Only one program is granted root access at a time with sudo, whereas su is a permanent administrator login. Sure Ubuntuâs implementation of sudo is terrible but with a bit of tweaking the /etc/sudoers file it can be altered.
