Hi,
This is my first post here, and I must say hardware is not my specialty (yet). I’ve been having a recurring problem.
My computer has trouble booting. The first time this happened it wouldn’t boot at all. I took it to a computer store and they said that there was a power surge and I needed a new motherboard.
Then when I got it home I noticed that I would have to press the power button several times before it would boot. IE: it would look like it was going to boot but then it would shut off. Back to the computer store. I got a replacement mobo on warranty.
Now, I am noticing the same problem. With an added bit of insight: When I try to boot, it will not if there is a cd in the cd drive. The only way I booted to post this is by powering up and quickly pressing eject. AND if I put the cd back in, once it revs up, the computer has a tendency of shutting off again.
Because of this, I suspect that it is the power supply. I’m guessing that somehow, the cdrom drawing voltage from the power supply (to rev up) is somehow overloading the system. (but what do i know :D)
Your theories and recommendations would be much appreciated.
Hardware:[ul]
[li]mb: MSI K8N Neo4 platinum
[/li][li]cpu: AMD athlon64 3000+
[/li][li]psu: turbolink atx no: 400U-420PS
[/li][/ul]
firstly Welcome to HWF
[QUOTE=jpalfree]
i would start by checking the boot order in the BIOS
BTW: i wouldn’t think it was the PSU, but to varify what is make and model of PSU?
BTW: i’d also probably reset the CMOS / BIOS[ot]and hope, as always[/ot]
BTW: if you don’t know how to reset the BIOS check here
I did try resetting the bios. Same problems.
What would the boot order have to do with it? Right now I have cdrom->HD->floppy. But the computer usually turns off within a couple seconds, much before it attempts to boot.
It’s strange, once out of ten times I will be able to use a cd…but the other times. It just shuts off when one is put in.
I thought I gave the make and model of the psu… but maybe I gave the wrong info… I’m new to this :D. What info exactly do you need?
thanks.
Change your power supply,also check your date and time on the computer.
[QUOTE=jpalfree]
sorry, my mistake, although i’ve never heard of the turbolink 400U-420PS (i assume it’s cos i’m in UK) however tomshardware.com appears to think their ok here try another known working powerful enough PSU, for your system
Edit: check out B’s PSU Sticky for advice on PSUs Here
