please help … i’ve got my friend’s cpu to reformat! it is working before i took it, but when i reach home and started it, it won’t boot! no display, no sound or beep, not even a single line! i try to replace the video card from my working pc but still nothing happens, then i change one by one starting from the power supply, then memory, then harddisk… i even try to remove the motherboard from the case then try to run, but still it won’t boot… what are the possible cause?! the only thing i haven’t replace yet is the processor… could this be the problem? thanx…
the CPU could have a case of chip creep! check your CPU is in its slot properly and check back!
P.S- you cant format a CPU!
