No INPUT SIGNAL
ok guys, we just put together a build for my brother in law, and we have an issue. We have the moniter plugged in and it gives us a “no input signal” message when I fire it up. We troubleshoot the monitor and everything is ok there. Im thinking it may be the BIOS or the RAM.
Hi,
You have not specified weather you are using a graphics card or on-board display controller. Reset the bios by shorting the cmos battery socket leads and try to boot again.
Is there any beep codes from the system ?
                                                               AJAI.M.S
RAM issue. Tiger Direct sent us bad RAM. troubeshoot with good RAM and it worked
