No Power after installing a new Motherboard
Just finished installing the following motherboard combo into a 250 Watt case, and no sign of any power in the case nor the board.
Biostar/Amptron M7NCD Socket A DDR MB with Athlon XP 1800+ (1.53Ghz) 266FSB CPU w/Fan with Memory (512MB PC3200) [MCFM]
BZBP#M7NCD-1800Memory
All connectors (power and on/off switches) have been doubly rechecked, and yet no power.
The screws holding the motherboard to the case have been loosen to allow for that as a source of the problem.
Anyone with suggestions as to what can be wrong???
This same case worked with a previous motherboard installation. http://www.hardwareforums.com/newthread.php?do=newthread&f=50#
Hot
Sounds like the power supply is just too weak, 250watts is probably to problem.
I agree. It really sounds like you don’t have enough juice to get going.
I got a 500W PSU today and when I put it in, it fixed all my problems.
^^Now, to add to that, all power supplies are NOT created equal. If you walk into a shop and buy a 600W power supply for $35, chances are it’s a POS (unless you’ve got coupons or some sale going on with the deal). Easiest thing to check is just judge by the weight. Heavier=better because more components are used in the unit, which in short, results in cleaner, better, steady power. Personally, I swear by Sparkle, but Antec is second. I’ve also been hearing some very, very good things about Thermaltake units.
Now, you shouldn’t need a 500W unit, but I would recommend spending a little extra on a good 400W or better unit to accomodate future expansion.
Gentlemen: (Ninja fetus; Big B; and Addis)
10/24/2004 9:05 AM EST Sunday:
Thank you all for the quick solution given.
Last night I purchased a new case with a 500W Power supply, and my son should receive it within a week.
I trust all will be solved when he reinstall the motherboard combo along with his other PCI board, and hard-drives.
Thanks again.
Herman Ortiz
[email protected]
B. I know i know i should look at stable voltages etc but PC World where i got it from told me that if it did any damage to my PC that was purely the PSUs fault (within the warranty) or it did not work they would give me a refund. You must understand that at this point i would try anything to get it working. It was actually a good PSU, a lot heavier than my cheap crappy 400W which weighed as much as a glass of milk. Now all i have to fix is my graphics card thingy.
Cool beans. I always have to stop and remember that the UK has a store called PC World. There’s a magazine over here in the US called PC World, which has had me thinking “I know that mag doesn’t sell anything…oh, wait, they’re from the UK smack
I did try to tell the guy at the help center that i really didn’t need a 500W, a 400W would do me, but he insisted that just because i had a GeForce FX card i’d need one.
[QUOTE=ortizSr]
Thanks again.
Herman Ortiz
[email protected]
Limiting Beliefs
They’re self-fulfilling prophecies. If you think you can’t, you’re right. If you think you can, you’re right. To change your life, change your mind
