Im quite new to all this so forgive me for sounding dumb :chk:
I have a problem with my Radeon 9200(well at least i think it is that). I had turned off the pc and next time i went to turn on, i had no screen output. I’ve checked all the cables, puled the card out and put it back in and still nothing. I think my card has fried or something else has happened and i just dont know what. Please give me any advice you can as im stuck on my P2 400mhz at mo!
No i tried takin the card outta this p2 but i dint realise the slot is diff, so couldnt try it, im thinkin of buyin a new one as in Jan im upgradin to a P4 3Ghz. Card aint a big thing for me tho as lack of dosh, will get a ok one and upgrade it when i can.
Check the pins on the moniter connection aren’t bent as this is a common mistake. also try your p2 system moniter on it to rule ou faulty moniter. i wouldn’t just give up just yet and but another i’d see if we can do anything with it first. hope this helps Dave :good:
hey, thanks for the advise but im usin the same screen, i built the athlon and to keep costs down just used scrren from p2, only 15 u c lol. So the screen does work as im usin it now, i just hope it is just the card as im meant to b sellin the mobo and chip to a mate when i get my P4
