Hi, I was making sure my memory was in properly because i had a problem with it so i took the memory out 2 512 mb sticks and put them back in how they were. However i started my computer up and i had a blank screen on my monitor saying No Signal Why has this suddenly came up isit something to do with my memory not been put back in properly or have i maybe accidently pulled a cable out of the computer??
It could be a lot of things. If you were taking out and replacing your RAM you may simply have knocked something loose. Do your fans come on? Is your hard-drive starting up? Does the power led come on? If so, it might be a problem with your RAM but also make sure that your graphics card isn’t loose and that the monitor itself is plugged in correctly.
[QUOTE=ThePenguinCometh]
I tryed to replace the ram again but this time the power just went off in about 5 seconds of turning it on. Now im really lost on what is happening at the moment, have i maybe put the memory in the wrong way or what?? The fans are working fine and everything and ive checked the wire was firmly in but its defiantly to do with the system because i connected my old comp system with using the same screen.
