No Sound =(
Well, We just bought and installed Windows XP, now theres no sound and theres installer disc with our speakers, I went through control panel etc to try to fix this, and i also looked on the net for any drivers. So, I’m stuck as to what I can do to fix this =(, I’d really appreciate any help with this, Thanks Alot =)
Check your device manager. Can you see any yellow exclamatery sign over there in front of sound?
If you run troubleshoot sound in windows, you will come across many solutions. I would recommend you to try that as well.
There’s a yellow exclamation mark over “Multimedia Audio Controller” But thats all, and I tried troubleshooting through control panel but it didn’t work. Apparently everytime our computer’s crashed the sounds gone too, if that makes a difference? I was never the one to fix it though :S
Did you get recovery CD with your PC. Is your sound onboard?
What did you do when your windows crashed?(Any installation of Software or Hardware)
Erm, the other times it crashed some dude we know re-installed windows for us, and they did everything, but it crashed again so we bought windows today and installed that. Someone made this pc for us though, so no recovery disc’s or anything, There’s no sound at all, the pc beeps instead :S
Have you got a soundcard or is it an onboard one?
Its gotta be a driver problem. My SB card doesnt do anything until I install the creative drivers. Xp doesnt cater for it.
I’m completely computer illiterate.. I haven’t a clue as to the difference. I just found a driver somewhere and installed it though, and now it plays, but i just can’t hear anything
Double click on the sound Icon and see if Master and Wave volume bar is up and not muted.
Edit: Check your player as well, is it mute? alternatively try on some other player to check the sound.
Yeah they’re all up, I just checked… I swear this pc just hates me L
It looks mad but sometimes happens so just to make sure…Check that you have inserted the speakers pins properly in the right port nd yea try to play the file in some other player as well.
Yup.. it’s all plugged in properly, and it plays in media player & there’s no sound, and it just wont start playing in itunes, but there not a warning message
Can u still see a yellow exclamatery sign in your Device Manager?
Nope
Have you got a sound Card or you use onboard?
I’m not sure :S I don’t know what onboard is?
What did you install when you said that I found driver CD. May be it could help to find out the difference. Alternatively, it will also help me finding latest driver for you sound then.
Onboard sounds means that your PC’s sound capability is incorporated into your motherboard. Do you have a seperate sound card?
It might also be worth downloading the following tools -particularly if you are try to get sound via Windows Media Player. Anyway, it’s worth a try!
Free-Codecs.com :: Download Cole2k Media Nero Audio Plugin Pack 1.5.3 Download XP Codec Pack 1.3.4 - XP Codec Pack is one of the most complete codec pack
do you know what motherboard you are using and what soundcard you have. If not, try installing Everest to see what hardwares you have. Then repost it back here so we can give you a link of the correct driver for your card.
Thanks alot for all your help guys.. I still wasn’t sure on all that stuff, but I just updated all the sound drivers and it works.. took long enough! Thanks alot everyone
