Hello,
Does anyone have any ideas what can make a low pitch scratch like sound when i’m on the windows desktop or some other application and when i start playing the sound’s pitch go higher, but not always, it seems to be more constant when old graphics are involved… i was playing the first Halo and it was making noises like crazy, but when i play something newer like Spaceforce it becomes intermitent. It seems that the noises are coming from the upper part of the case… where the cpu, psu, memorys and dvd are located. Flopy, hd and vcard are on lower bays so i don’t belive it’s coming from any of them…
I have a:
k8v-x
athlon 3000+ 2ghz
sata seagate 80gb
nvidia 6800 extreme
coletek 500w psu
sms stabilizer
working without any oc, actualy i tryed to underclock to see if the noises improves, without luck… ![]()
I had a problem several months ago where all my usb ports went bad, a lot of blue screen of death (“irq not equal or less”) AND THE DAMNED NOISES. At that time i disovered that the psu was fryed and had the psu replaced for this tougher one and it was fine until now…
anyones has any thoughts on this?? Thanks !!
