My phone has suddently stopped receiving proper Wifi. at home, it finds my wifi network but when I try to browse, it just hangs there. At another site, the phone simply didn’t see all the networks that my computer could, although the network strenght of all relevant ones was very good.
So, what could be the problem - physical damage (i’ve dropped it once past the several days, but didn’t notice anything, plus it has fallen on much harder surfaces and from higher points that the other day…), emerging software bug?
Yeah, that’s what I thought, too. Although, I’ve heard that at least SonyEricsson’s Symbian S60 phones get clogged up after 6 months or so and are unusable unless you reinstall the OS or something… so I thought that my E63 had the same kind of issue. Anyways, now it has gone to normal again. I don’t know - maybe dropping it a second time did the trick. Almost like with russian tech (no offense there) - if it’s not working, hit it.
and the second drop fixed dislocated hardware? kinda weird. but it’s been working quite fine since my last post, so we’ll see once I drop the phone again
But the most interesting thing is that I use a kind of wallet for the phone, which acts like something protective and should suck up all the kinetic force. Cause, of course, I’ve dropped the phone on some serious floor when it was bare and no harm… I don’t just don’t know, really. Can’t be positive, but fact is that the networking problems were not only at home, but also at another location. Couldn’t get to test it anywhere else.
If you are facing any such problem, try to do it yourself. You can also go to nokia care to look for a solution. They may consider your phone for a replacement otherwise get it repaired from market.
