While the [noparse][noparse][/noparse] option is only meant to stop bbcode from being parsed, it would be useful if it stopped all parsing of text (de-capitalization, removing extra spaces etc) as sometimes you want the extra spaces!
for example, the output of fdisk listing partitions contains extra spaces to make the columns lines up! (or putting a very important part of a post in capitals, ie something that might cause data loss)
Sniper
July 28, 2008, 6:59pm
2
I think the code tag would be best suited for that purpose
e.g. [code]Processes: 87 total, 4 running, 3 stuck, 80 sleeping… 447 threads 19:56:42
Load Avg: 0.40, 0.32, 0.25 CPU usage: 1.66% user, 2.98% sys, 95.36% idle
SharedLibs: num = 2, resident = 128K code, 0 data, 0 linkedit.
MemRegions: num = 36982, resident = 821M + 11M private, 432M shared.
PhysMem: 639M wired, 1984M active, 667M inactive, 3303M used, 2841M free.
VM: 17G + 375M 202877(0) pageins, 0(0) pageouts
PID COMMAND %CPU TIME #TH #PRTS #MREGS RPRVT RSHRD RSIZE VSIZE
69325 AppleMobil 0.0% 0:00.19 1 43 459 6184K 69M 20M 132M
69318 iTunes 0.0% 0:21.21 13 235 937 26M 101M 68M 556M
64885 Speed Down 0.0% 1:09.91 6 146 645 11M 97M 41M 487M
46775 top 11.4% 0:01.06 1 18 94 968K 6392K 3808K 27M
46764 bash 0.0% 0:00.00 1 14 42 368K 2208K 1576K 21M
46763 login 0.0% 0:00.02 1 17 223 1632K 19M 7216K 47M
45915 mdworker 0.0% 0:00.27 3 67 337 3936K 40M 15M 96M
43204 ssh-agent 0.0% 0:00.03 1 23 112 2176K 9108K 6424K 33M
38492 Terminal 3.6% 0:07.88 5 107- 619 7608K 78M 33M 455M
37277 vmware-vmx 9.0% 2:36:12 24 166 1468 10M 60M 573M 1000M
37264 vmware 0.0% 0:55.94 18 256 999 52M 98M 92M 573M
33011 Things 0.0% 0:03.37 20 149 830 27M 103M 63M 518M
24310 firefox-bi 4.9% 1:58:08 24 696 3200 198M 117M 307M 1020M
16562 Mailplane 0.9% 12:55.80 19 268 3456 81M 110M 201M 648M
5736 launchd 0.0% 0:13.76 3 24 44 172K 1792K 996K 20M
1171 AppleSpell 0.0% 0:00.74 1 60 166 2044K 25M 12M 60M
[/code]
