Not sure where to post this...but im having major issues.
So I dont know what happened but i was just wasting time online, when i closed netscape I noticed that my background had been changed to this advertisement for spyware. No matter what i do i cant seem to change it. I went into the control panal and tried to change it but it doesnt seem to be working.
if someone could help me out that would be great
thanks
chelsea :confused:
Sounds like you got some adware (ironically enough). Get either [google]Spybot[/google] or [google]Ad-aware[/google] and scan your system.
I’d do a virus scan aswell. Just to check.
[QUOTE=Big B]
I’d say get both! Also, I’d recommend AVG Free to make sure you’re virus-free.
Is it black with yellow text?
If so it’s what my brother had a couple days ago. You can drag it down a bit and then close it as normal.
