hello I’ve made a booboo, have purchased a very expensife item on ebay, it was star trek whole 7 seasons (about 48dvds) but I didn’t read the description correctly, he said
“The discs are multi-region NTSC/PAL compatible, so should play on most MODERN DVD players (please check that you have a Multi-region DVD player as refunds will not be given for people whose hardware doesn’t support multi-region).”
err, im confused, does he mean each individual dvd is pal AND ntsc, or does he mean some dvds are pal and the others are ntsc format. is it possible to have a single dvd that has both compatibility? - if so will it work on a stand alone region2 (pal) pc dvd-rw /rom drive
The guy says Multi-region…they will be region 0, which means they are region free ie they play on all dvd players.
Your PC will defiantly play ntsc (if it doesnt you will be able to make it play ntsc!) and like I said ive never come across a dvd player which wont play both ntsc and pal. Flick through the settings on your dvd player, there will surely be an option. If its not in the menus it will probably be a switch on the back… ntsc–pal–auto.
thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you you’ve put a biiig strain from me head thanks very much
in about a wk when i get the dvds if it doesnt work ill post a new forum being greedy and shouting for more SOS trying to get it to work wiv NTSC (if need be like you say)
