nvidia geforce mx 4000 driver problem
When I install the driver and then reboot. The window logo comes up and then the screen goes blank. The computer restarts again and then it gives me the choices of chooseing safe mode or normal mode. Have to go into safe mode. When I am in safe mode I uninstall the video card and reboot. And then windows boots up. The driver that windows uses is the default one.
I have tried different video card drivers and they give me the samething. I did get one driver to work for awhile and then the samething happen.
Does somebody know of a web site were I can get a video card driver that workers. Please help
Running: Windows xp sp2
Note: video card is made by “BFG” if that helps any
Thank You
First, if you’re running XP turn off system restore if you’re going to use non Digitally Signed drivers. WinXP tends to roll-back non-signed drivers on occasion, causing massive problems. Next, get your drivers straight from nvidia.com. Since they made the chipset, their drivers will work perfectly with your card. Alternately you can get gaming performance/overclocking drivers from omegadrivers.net.
