That ocing utility came with my mobo, looks really good but I’m just not sure what to tweak.
http://img262.imageshack.us/img262/2304/easytune42me.jpg
What do you suggest I bump things up to? I wan’t to concentrate on the cpu so what would you say I should bump up the system bus and multiplier to? How about the ram voltage, it’s at 2.5 now. 2? I’m looking at ocing the thing to around 2.2Ghz or so, 400Mhz shouldn’t hurn too much on a Winchester. Or do you suggest I do this the old fashioned way. If you you’ll have to walk me through it as I’ve never fiddled around with cpu ocing. Thanks big time all.
i got Ntune, and Ai NOS, i use those, pretty good
but software lacks much potential compared to the old skool bios ways
I’d take to about 205 and run memtest. Since you have generic ram you won’t be getting far.
You’re refering to the system bus right, not ASYNC for the ram? I’ll have to get memtest…Thanks.
oh, yep. Also, changing FSB/RAM ratio to anything but 1:1 will cause performance loss in almost any case.
