yesterday i was playing the witcher. once (druing the ice plains if that matters) the game froze up my pc and i had to do a forced shutdown. when i tried to restart i got a long beep. i took my vid card out and dusted it off a bit and everything started working again.
this happened again after the credits of the ending of the witcher rolled. i had to force a shutdown. but, this time i just took the vid card out, didn’t dust it, stuck it back in and everything worked fine.
then, last night i turned off my pc, everything shut down normally. then i realized i forgot something, tried to turn it back on and got nothing but “eeeeeeeeeeeeeeeeeeeee”… a long beep.
since then i have tried putting ram in different slots, trying different ram, taking my vid card completely apart and dusting it (although i did not reapply the heat paste as i do not have any. whoever decided to put the screws to the fan housing on the bottom so that you have to take off the entire heat sink should be jailed), dusting out the rest of the pc, taking out my tv tuner and sound card and putting the back in after dusting…
i don’t know what could be causing this.
the system is
biostar tforce 550 motherboad
amd athlon 5600+ cpu
msi 8600 gts oc edition
(was till i started fiddling about) 4 gigs gskill ram. i tried my old geil ram and the same problem occurred. and i tried only using one stick and using different slot. and yes, the locks locked in place.
chaintech av 710 sound card
avermedia tv tuner card
corsair hx520w power supply
i have also tried unhooking my keyboard with no luck
i have no idea what one long beep means as it seems there is not bios code associated with a singular and only one long beep.
i should also mention that my screen stays black. i cannot see anything. no bios page, no nothing. i just get one long beep, then silence, then if i press f1 like i normally would on start up my mouse and keyboard lights go off and come back on. when i press the power button to shutdown after this point it takes a second to do so like it would if it’s reached the startup page.
what do you think is causing the issue?
